Old 06-09-2010
gtunison is on a distinguished road
hatch rebuild
Greetings,
The lazerette hatch on my C24 was built with a mahogany frame, 3/8 plywood inset and mahogany planks overlapping the frame by about a half inch.
I have access to thick enough mahogany stock to eliminate the plywood (it rotted) and just route the new boards to fit in the frame and overlap to seal it with some Sikaflex.
Anyone see a problem with this method?
Why would the factory use plywood under the boards?
Will the thicker boards change their shape more with moisture fluctuations?
Eagerly,
Greg
MacGregor 21 rebuild Jolley Roger MacGregor 21 03-08-2011 12:43 AM
The Cal29 forward hatch rebuild tommays Cal 9 11-07-2010 06:02 PM
Effectively sealing forward hatch Petar Gear & Maintenance 9 01-27-2006 08:07 AM
ericson 35 II hatch help yareII Gear & Maintenance 1 01-26-2005 12:48 PM
Resolving Hatch and Portlight Problems Tom Wood Gear and Maintenance Articles 0 03-17-2003 07:00 PM
