Old 06-09-2010
Justa
Location: Strasburg, Virginia (I need more work near the 'Neck')
seaspot is on a distinguished road
Harken furler foil replacement
I had to drop my mast this year to do a needed rewire and adding masthead lights. In the process of dropping the mast a couple pieces of the double grooved foil on the Harken roller furler got damaged.
Does anyone know where to get replacements? Do I just contact harken directly?
Does anybody know how much these things run? I'm wondering if I'd just be better off replacing the whole thing, since it's an older model anyway.
Old 06-10-2010
knothead's Avatar
Sailing Services - Rigging, Lifelines, Winches, Furling Systems, Supplies, Ropes
Ron Paul 2012
"wikijar"
Old 06-10-2010
KeelHaulin's Avatar
STARBOARD!!
KeelHaulin will become famous soon enough KeelHaulin will become famous soon enough
It depends on what model you have; some foils are not available anymore. I would contact Harken if you know the model number of the furler system. Otherwise you would be looking for spares from a place like Minneys - MINNEY'S YACHT SURPLUS - WE MAKE BOATING AFFORDABLE
Headstay replacement and Harken MkI furler josrulz Gear & Maintenance 13 04-22-2011 07:47 AM
Harken Furler Question brich001 Gear & Maintenance 6 05-05-2010 10:35 PM
Replacement Furler CaptainDan99 Gear & Maintenance 5 04-15-2010 09:58 PM
Harken MKI furler MtHopeBay Gear & Maintenance 7 01-24-2010 12:28 AM
Needed: Harken Mk III Furler Drum scraph Gear & Maintenance 1 01-11-2010 12:47 AM
