Old 06-10-2010
Patapsco is on a distinguished road
Tohatsu 6 hp spewing gasoline
After I drain my carburetor, my engine runs for about 10 seconds and then dies. While it's running, gas spews every where. Is there an easy fix for this?
Old 06-10-2010
Hollen is on a distinguished road
OB problems
I am sure you will have a lot of help with this but since I am up late I will tell you how I fixed the same problem. You have to take off the carburetor, remove the float bowl, remove the float and clean the pin (don't forget the hole it slides through). You will probably also find all of your jets plugged, for the same reason. This is all easy to do, the hard part is not dropping anything while doing it. The reason this happens is you didn't run your outboard dry of fuel the last time you ran it (or drained the float bowl with the drain plug). Fuel left standing in the bowl will solidify faster than you would imagine.
Steve Hollen
SV Andalucia
Mazatlan, Mexico
Tohastsu - 8hp 4cycle - tech questions LarryandSusanMacDonald Gear & Maintenance 41 03-12-2010 11:33 AM
Safety Check Mark Matthews Learning to Sail Articles 0 01-25-2000 07:00 PM
Safety Check Mark Matthews Seamanship Articles 0 01-25-2000 07:00 PM
Safety Check Mark Matthews Gear and Maintenance Articles 0 01-25-2000 07:00 PM
Safety Check Mark Matthews Her Sailnet Articles 0 01-25-2000 07:00 PM
