06-11-2010
Islander 32' Mischief
Originally Posted by captbillc
i don't know what you mean by a clamshell rudder. i am assuming it is not cutaway for the prop. i believe the clearance recommended between the prop & the hull is about 20% of the radius of the propellor. too close will cause vibration. you will get better steering under power if the prop is fairly close the the rudder.
There is a cutaway for the prop, the rudder is hinged to the rear of the keel as many of these old keels were. I agree that the spacing is less than adequate and have pretty well talked myself into finding a new shaft today.
Gene, I dont believe I have that kind of space, the engine in the boat was an aftermarket addition and somewhat larger than the original atomic four it was originally launched with.
