Old 06-10-2010
sailguy40's Avatar
sailguy40 is on a distinguished road
Onboard Sink
Maybe someone can give some pointers here. I want to get the small sink on my boat working, Nothing has been modified and it is the original sink onboard the Oday 22's from what I seen. First I have the onboard water tank and a hose runs from that to the sink. It all appears to be intact. Basically, my main question is, how do these little sinks on these boats work? Is there an electric water pump or does it sippon through the hose some way? Reason I ask is because I have not seen a pump anywhere. It may come in handy to have it working if I want to wash a few dishes, my hands, brush my teeth or anything else I may need if for.
Old 06-11-2010
jbondy's Avatar
Senior Mumble
jbondy is on a distinguished road
You can have a pressurized fresh water system, in which case there will be an electric pump that maintains the pressure from the water tank to the faucet. On our galley sink, we have an additional faucet that is fed by a foot pump in case there is something wrong with the pressurized system. This could be the primary means of providing water to the faucet, in which case it is not a pressurized system. I've seen manual pumps at the faucet itself. I've never seen a faucet fed by siphon, though.
Tell us more.
Old 06-11-2010
1984 O'Day 26 - Lazy Dog
bacinmass is on a distinguished road
My experience has been on the O'Days there is a manual pump next to the sink. I had to replace both of mine (head and galley) as they were worn out after 25 years. Is there a pump next to your sink? Or a hole in the countertop where a pump used to be?
Old 06-12-2010
GraemeInCanada is on a distinguished road
Most likely a hand or foot pump kind of thing. I can definitely recommend from experience to make the change to an electric pump as it's very difficult to do anything with just one hand (being that one hand has to always pump). Although if it's a foot pump then that's great. For such a small boat I don't think it would be worth it to install a pressurized system.
Anyways, it's all very simple, there is usually a water tank or bladder to hold the water, an electric pump with a switch at the faucet or a hand or foot pump and of course the faucet itself. Buying a faucet with a switch in it isn't much, pumps are cheap too I think, then you just have to plumb it and hook up the electricity. Good project I think.
My blog on boat related stuff:
Old 06-12-2010
JimsCAL's Avatar
JimsCAL is on a distinguished road
Easiest and cheapest install would be a hand pump like a Whale or Fynspray. Especially since the tank and hose are already there. Not really worth putting in an electrical pump system and if I remember the ODay 22 interior, a foot pump would be awkward.
Old 06-12-2010
sailguy40's Avatar
Hi guys, thanks for the advice. Here is a quick video clip of my Oday 22 interior. You can see the sink there. I looked today and I did not see anything electrical nor did I see a foot pump. I am thinking it has to be all manual. Is that lever on the faucet a manual hand pump? If so, I may just need to fill my tank up completely with water and can get it working. I think I am thinking to complex here, I was looking for electric pump system or something. Thought I would here something if I turned the faucet on but nothing. I was just not aware how it works, none of my powerboats ever had a sink since none of them even had a cabin.
YouTube - My Oday 22
Old 06-12-2010
mitiempo's Avatar
Yup, it's a manual water pump.
Brian
Old 06-12-2010
sailguy40's Avatar
Well, that confirms I am probably good to go then, just need to fill the tank up with water. Thanks for verifying this.
Old 06-13-2010
nightowle's Avatar
nightowle is on a distinguished road
you may need to 'prime' the pump first. At least to get pressure into the line. Sometimes the handpumps to wear out and become useless and require replacement.
________
S/V Don't Panic!
O'Day 27
Seattle, WA
“Navigare necesse est, vivere non est necesse” To Sail is vital, to live is not.
Old 06-13-2010
ulferlingsson is on a distinguished road
On my previous boat the tank was higher than the sink so it ran by itself, but I put in a bigger tank low down, and a foot pump. I really like those foot pumps, wouldn't want to pump a lot of water with a hand pump.
How does a sink drain work? jarcher Gear & Maintenance 17 01-30-2010 08:24 PM
What is OnBoard? @ Sail Search Blog NewsReader News Feeds 0 04-19-2006 06:16 AM
Siphon through Sink? NbyNW Learning to Sail 1 06-01-2005 07:57 AM
Leaking Seacocks and Sink Drains Tom Wood Buying a Boat Articles 0 09-11-2002 08:00 PM
Leaking Seacocks and Sink Drains Tom Wood Gear and Maintenance Articles 0 09-11-2002 08:00 PM
