Old 03-20-2003
kimberlite is on a distinguished road
varnish cleaner
what do you use to clean fingerprints etc off of a very highly varnished mahogany interior?
thanks
eric
Old 03-20-2003
RichH's Avatar
RichH will become famous soon enough
varnish cleaner
Oil based soap. eg.: Murphy''s Oil Soap.
If that doesnt do it, a single drop of tung oil rubbed into the finish with a bare clean hand (in the direction of the wood grain only) until the oil dries (from the heat of your hand rubbing) and the gloss is restored.
If the ''prints'' still dont remove, .... get *rottenstone* from a paint store. Thoroughly clean and wet your bare hand. Sprinkle a *small amount* of rottenstone to the wet hand and rub *with* the grain direction until the hand begins to dry and the rotten stone makes a paste (on your hand) .... continue stroking the surface until the level of ultra-gloss is restored. Then clean the rotten stone off with a few drops of tung oil (olive oil if you cant find tung oil) rubbing with a bare hand until the oil dries into the finish ..... will be smooth and super-glossy as original.
Old 03-21-2003
kimberlt is on a distinguished road
varnish cleaner
ONE PERSON SUGGESTED WHITE VINEGAR AND WATER
Teak Cleaner docket Gear & Maintenance 2 08-19-2004 02:57 AM
varnish mikehoyt Gear & Maintenance 0 06-03-2004 06:29 AM
Interlux Perfection Varnish (2 part) mikehoyt Gear & Maintenance 0 05-31-2004 05:50 AM
varnish removal joseph53p Gear & Maintenance 3 11-29-2003 07:12 AM
Varnish remains off Deck jb Gear & Maintenance 3 04-28-2002 08:38 AM
