06-12-2010
It looks like water has intruded into that rudder... that's not good. You really need to know if the rudder stock and web have been compromised or not. You can't do that without looking at them, and that requires the rudder to be cut open and then, if they are okay, you can often close it back up and re-build it fairly easily. Just filling it with epoxy may lead to the rudder failing suddenly later on, and that could be really bad.
