06-14-2010
I'd point out that without removing the cause of the mold/mildew, fighting it is a losing battle. Having a dry cabin with no leaks is a key part of the solution—and fixing all the leaks that are letting water into the cabin is the first step. Then, once you've fixed the leaks, having decent ventilation of the ENTIRE CABIN will go a long way to preventing mold/mildew from returning.
