06-14-2010
I've used them but not on a WP. The limiting factor "should" be the strength of the forestay and backstay. In theory, one of those should burst (rather violently) before you can rip any fitting out of the boat or the masthead. But in practice...you'd be safer asking the maker what the maximum safe tension is, and then of course using a tension guage on the hydraulics, or a pressure guage that you can correlate to tension, so you don't exceed the design parameters.
And of course, remember to slack it off before leaving the boat.
The only hydraulics I've used fail if they fail. That is, if the cylinder loses pressure (usually from a seal leaking) it is simply lost, and the cylinder extends out to full length. The "locking option" sounds nice but I suspect something like a couple of bulldog clamps and a spare piece of cable could be used to a similar effect.
I haven't looked into what is available out there, but surely someone is making backstay adjusters with a pressure relief valve on them, i.e. if your rigging can take 8,000# of tension, a hydraulic rig should be able to pop a safety valve, or hit a limiter, so it can't put more than 6-7,000# on?
