06-15-2010
Originally Posted by Grumpymx
Hello,
I have a Islander 37ms, a keel stepped masthead sloop with single spreaders that run straight out from the mast, fore and aft lower stays, roller fuller on the fore stay, and a single back stay. The aluminum mast extends 40' above the deck.
It is very hard to get any mast pre-bend on this rig without cranking down the forward lowers and being a little light on the aft lowers, and then it ain't much bend.
I am going to paint the spreaders and was thinking of having a shop put a 3 or 4 degree angle on the spreader brackets. The thought here is that I would then add some pre-bend to mast by the always snug upper stays pushing the spreaders at the forward 3 to 4 degree angle instead of straight into the mast. Then I could just set the lowers to hold it where I want it to stay.
I am looking for opinions. Do you think this work without causing other issues, or problems with the spreaders/mounts ?
Thank you in advance for your assistance
I have to ask why you feel you need to redesign your rig.
Maybe you are as qualified as the guys who designed your boat. I don't know. But I generally figure that the Naval Architects who designed the boat are likely to have done a better job than I can do.
Having said that, I would probably start with an adjustable backstay.
Ron Paul 2012
"wikijar"
