OK guys.. stay with me! I'll send the consultation bill to .....
For those that know how to solder or braze, know how to use refrigerants. layout and wire controls. It's easy to take a window unit,separate all the components
Scrap the condenser coil. get a cupronickle heat exchanger, water pump, some copper tubing and refrigeration valves build an enclosure around the evap and fan, don't forget a way to catch and drain the condensation from the evap. add some flex ducts, hook it all up wire it, you would need some relays and a thermostat. but they should be 12 volt rather then the 24 volt the hvac industry uses. Oh.. this is all based on finding places to install this "system" on you boat
Thermostat is basically 2 or 3 switches. You would need 3 wires. one for fan, one for compressor relay, one for the control voltage source. It' s good to know relay and contact terms too.
http://www.ehow.com/how_2090373_read...-diagrams.html
and.
http://www.wiringdiagrams21.com/2008...agrams-symbols
the relay should/would need is a DPDT with 12 volt dc coil. automotive type would work. the compresor relay is heavy duty. a automotive type solinoid would work. Mode of operation would be; the ac calls for cooling on rise in temp. makes the circuit to the fan and comp. (the pump is wired in with the system too) I'm not even going to explain reverse cycle wiring!
When your done, it would look like a "marine" ac unit in the end anyway. 4-600 for a window unit 1500 -2000 for "marine" that does the same thing. but the labor would be pretty time consuming. All that and you would also need to know how to evac, charge and know how to get the cooling pressures correct.
If you have a larger boat a "water source a/c or heat pump is basically the same as a Marine ac or reverse cycle unit. Big differance would be cabinet metals that rust out.
Most residential ductless units start around 9000 btuh, but they would really need modifications to work on a boat. On ship it would be like doing a hotel or motel. You could use just the wall hung part of a duct less system but you would need a water cooled condensing unit that would have to be built most likely.
I've not been on my boat in 2 weeks because of the heat! ARRRRG and it' only 10mins from my house! WAAAAA
