06-18-2010
Removing numbers from a sail
I've got big numbers on my sail I'd like to remove. For the heck of it, I peeled back a corner a little, and the number did peel back, except there was a little glue residue at the edge of the number, as if a tiny bit of dirty glue at the outline of the number. My next step is to again peel back that corner, then use Glue-gone, goof-off or even WD-40 to remove the glue. I've used wd-40 with success to rempove sticker glue from plastics and it appears harmless although messy.
Anyone know the best way to remove number stickers from Dacron sails??
-jeff
Preserved Killick
Seagrass
Boothbay Harbor, ME
Alberg 30: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
