06-18-2010
IMHO, you'd be better off hoisting a Davis Echomaster Deluxe on a halyard when needed, rather than mounting one to the mast. The Echomaster rated better than the medium TriLens, while the Echomax 230 did a bit better IIRC, but the Echomaster is far less expensive. The Echomax is about $400. The Trilens, medium size, is about $300. The Davis Echomaster Deluxe is only $80.  Neither the Trilens or the Echomax come with mounting brackets IIRC. The Davis Echomaster Deluxe comes with a halyard mount kit.
I have mine rigged to be hoisted up to the second set of spreaders. The spreaders have two blocks, mounted about a foot apart and the halyard goes to a block on the deck. It is essentially a continuous line, so that the Echomaster doesn't swing much. The reason for the two blocks at the spreader is to prevent the Echomaster from chafing the halyard.
