06-18-2010
Mceveritt,
Had a Coronado 25 with a well at about 4,000 lbs..
Long story short, had a 6hp which was marginal for San Francisco Bay. went to a 15hp, same size as the 9.9, which may have been OK,
and it really got the job done. If I was to do it over, controls in the
cockpit and electric start would be good. Don't know what your water / weather conditions are but suggest you get the strongest
motor with the longest shaft that will fit in the well. My guess is that a 6 hp
with high thrust prop and long shaft would be adequate for your boat. I agree with MarkCK's post. Sometimes there is nothing like all the thrust you can get.
Just my two cents worth, Dabnis
