06-20-2010
Originally Posted by harbin2
I'm trying to figure out if I need to add alcohol. I have a tank that is 8" in diameter. I emtied it over the winter and "cleaned" it out with some fresh alcohol. I added a gallon. I just got back from a 2 week cruise on the (Chesapeake) Bay and used the stove fairly extensively. I want to know how much I used.
OK - the formula for the volume of a cylinder is Pi x r squared x the height. I measured the depth at 3.5" with a wooden dowel.
My problem is I'm not sure about the units.
To come close to what I'd expect the volume to be, I converted the radius and the height to feet. That results in a volume of .916 gallons.
However, it seems like I have had to use more fuel than .084 gallons.
I should probably have posted this to a math forum but I figure someone here has done this calculation before (or has some more practical method for determining how much fuel is left).
harbin2
Islander 30 Bahama
V=(pi)(r^2)h
V=(3.14)(4^2)(3.5)
V=(3.14)(16)(3.5)
V=175.84 cubic inches
175.84 / 231 (cubic inches per gallon) = 0.7612 gallons
Why did I get something different than you did ?
I'll try it in feet too and see if I get the same thing.
8 in diameter = 0.3333 ft
3.5 in = 0.2917 ft
V=(pi)(r^2)h
V=(3.14)(0.3333^2)(0.2917)
V=0.10175 cubic feet
0.10175 / 0.133680556 (cubic feet per gallon) = 0.7611 gallons
Same result either way.
Just holding up your hands and making an 8 inch diameter circle and imagining that it is 3.5 inches high, I don't see how that could hold as much as a gallon container of milk, so I think the 0.7612 gallons is probably right.
What are you pretending not to know ?
