06-22-2010
Originally Posted by labestia
Hello:
In the process of re-bedding the Hull-Deck Joint of my 44’ sailboat I have some doubts:
1. After removing all the hardware from the Hull-Deck Joint on the starboard side (leaving in the port’s side), will I be able to just separate the joint, to be cleaned of old bedding material and re-bedding it by using shims?
It depends, on some boats the hull-deck join is glassed over or glued together, so merely removing the screws and hardware may not allow you to separate the two parts.
2. How much can I expect to separate the surfaces?
It depends on what else is connecting the two pieces. Bulkheads, furniture, etc may also be tabbed to both, which would restrict the amount they can separate easily.
3. Is there a chance that when I remove the shims the old screw holes (which are in good shape) will not realign?
a. If so, any suggestions on how to avoid this?
I hope you've taken the rig off and removed all the tension on the hull and deck from the rigging. Keeping a few long screws through a few of the holes will help keep the two in alignment—say one screw every six feet or so.
La Bestia  [/QUOTE]
