I've removed all the sealant in the keel hull joint (I'm not dropping the keel this year.......that requires cutting out the floor and pulling the mast -- negatory) and was originally planning on sealing it with 5200
keel is cast iron, flanged (as in it's through bolted into the bilge, not cast in j-bolts)
after some reading/research and speaking with West Systems -- I'm now considering a few options:
1. only seal joint with 5200 (caulk immediately after final wire brushing of iron)
2. seal joint with 5200, grind back 2-4" above joint on the hull and 2-4" below joint on keel and glass over sealed joint using glass laminted with G/flex Epoxy
3. seal joint using thickened G/flex Epoxy, grind back 2" above/below joint as well
4. seal joint using thicken g/flex and laminate over it with g/flex glass
also interested in pettit's flexypoxy -- also looks good -- but I called both West's and Pettit's tech support line, at West got someone knowledgeable -- an engineer and at Pettit got someone with ****** who didn't seem to know much more than the product spec sheets, so I'm leaning towards West
my gut says 5200 + gflex glass, but I'm considering an all G/flex solution, keel is a fin and I know it moves some so obviously need something flexible
anyone have real world experience with either G/flex or Pettit's Flexypoxy?
Pettit Spec Sheet:
http://www.pettitpaint.com/fileshare...ds/1707628.pdf
G/Flex Info:
G/flex Epoxies
Thanks!
