Old 06-22-2010
nickhughes is on a distinguished road
Advice for Rebedding and Aluminium Toerail
Water is seeping under the aluminum toerail of my Compass Easterly 30 and staining the topsides and doing god knows what to the inside of the the hull.
I am therefore planning to remove, repaint and replace the toerail.
My current thinking is, once removed, to fill in the current screw holes with epoxy and then drill a small guide hole. Then re-bed the rail using new self-tapping screws and Butyl tape as a seal between the underside of the rail and the deck.
My main concerns are:
i) Is filling the current holes with epoxy and reusing them to re-bed the rail a viable approach?
ii) Is the Butyl tape enough to keep water out of from under the rail and in the screw holes in itself or do I need to use anything in addition?
iii) Not all the holes are accessible from inside the boat, but should I consider using bolts for those that are?
Any additional advice / dire warnings appreciated.
Thanks,
Nick
Old 06-22-2010
Is the deck cored in that area? If so, making sure you've properly potted each of the fastener holes is key to preventing long-term damage.
Yes, butyl tape should keep the water out without anything else. Follow Maine Sail's guide to using Butyl Tape.
Through bolt what you can. Through-bolting is usually stronger than screws, especially in fiberglass.
Thanks,
Nick
Aluminium for high latitude sailing? whigmaleerie Cruising & Liveaboard Forum 10 11-24-2009 09:32 PM
wood spars vs aluminium IanD Boat Review and Purchase Forum 3 10-17-2008 09:48 PM
Looking for advice on "Restoring" an old aluminium boom. Northbeach Gear & Maintenance 14 01-04-2007 05:12 AM
aluminium prep oz_hole Gear & Maintenance 3 01-22-2003 02:58 PM
