converting raw water head to fresh water - Page 2 - SailNet Community
post #11 of 18 Old 06-24-2010
Using the head sink drain line allows the sink to act as a vacuum break and eliminates any risk of cross-contamination.
Originally Posted by RichH View Post
You should consider to follow standard 'sanitary' piping rules and regs. so that the fresh water system isnt 'retrograde contaminated' from the toilet/head !!!!
... and this isnt easy to do on a boat. Check valves, y valves, etc. CAN NOT do the job of protecting a fresh water system from retrograde contamination.
To do this job properly you have to 'cobble' a system that functions similarly to a household toilet .... the water system delivers to ***separate Tank*** and the separate tank delivers to the toilet ****through an 'air gap'****. The separate tank has a valve on the INLET of the fresh water to the separate tank and that valve ***IS ABOVE THE LEVEL OF THE WATER in the separate tank***. Thats the NSF and 'sanitary' regs.' for all 'toilets' in the USA where the 'supply water' is connected to POTABLE water. This PREVENTS harmful bacteria from entering 'retrograde' into the potable water supply ... bacteria moving against the normal flow of water.
sailingdog is offline
post #12 of 18 Old 06-24-2010
Paul J - C27 Owner
simple solution
On my C27, the sink drain and head raw water intake use the same through hull. I leave the through hull valve closed. To flush the head, fill the sink 1/2full with clean tank water, then switch head to wet bowl and pump. This drains the sink into the intake line of the head. No replumbing necessary and give you option of using raw water if you prefer by simply opening the seacock on the through hull.
PaulRJordan is offline
post #13 of 18 Old 06-24-2010
Iroquois MkII
I keep it a lot simpler than this, I just have a 1 gallon jug of spring water on the floor in the head. When I need to flush, just pour some in the bowl.
LookingForCruiser is offline
post #14 of 18 Old 06-25-2010
The problem with that is that it will put extra wear on the head pump's seals, since the intake side is constantly working without any lubrication. The pumps on the heads are not designed to work that way. It is a really bad idea, at least in the long term, to use a head that way. Also, 1 gallon won't last for more than a few flushes, if you're flushing with enough water to clear the lines of any waste. If you're not clearing the lines of waste, then, you're asking for a nasty hose permeation/clogging problem to set in.
post #15 of 18 Old 06-01-2011
turbulicity's Avatar
Hope I can revive this thread a little. I am living aboard and I currently flush with raw water. It smells although the head is used frequently.
I don't like the idea of T'ing from sink discharge thru-hull since that means I either have to pump everything from sink to the holding tank or constantly have to reach in and turn the thru hull on and off.
I was thinking of T-ing the head inlet from the sink drain hose but at a position just above the waterline. After all, from waterline up to the sink, the hose is filled with fresh water all the time. So, I can wet-pump the head a couple of times without closing the sink discharge thru-hull and it would pull in the fresh water standing in the hose. If more is needed, run the faucet a little and pump more.
Does this sound reasonable? Am I missing something?
1978 Gulfstar 50'
Clark Sailing Dinghy 10'
turbulicity is offline
post #16 of 18 Old 06-01-2011
mitiempo's Avatar
If the T is in the drain above the waterline you will pump air.
Brian
mitiempo is offline
post #17 of 18 Old 06-01-2011
Stu Jackson's Avatar
Holding Tank Failure & Fresh Water to Head from the Sink in the Head FLIX
Two pages, with discussion about dos and don'ts.
Stu Jackson, Catalina 34, 1986, M25 engine, Rocna 10 (22#), Maple Bay, BC, Canada
Stu Jackson is offline
post #18 of 18 Old 06-02-2011
Sorry, didn't make this clear enough. My sink (as most do, I suspect) drains rather slowly. So I can T from just above the waterline on the sink drain hose. Run the faucet and start pumping the head. Would be nice to have a valve there at the T-joint so that I can go back to raw water flushing on long trips.
1978 Gulfstar 50'
Engine Overheating-Restricted raw water rk6johnson Gear & Maintenance 1 10-30-2009 11:54 AM
Water, Precious Water Michael Carr Cruising Articles 0 09-02-2004 08:00 PM
Water, Water Everywhere Tania Aebi Cruising Articles 0 06-14-2004 08:00 PM
Updating Your Head Sue & Larry Gear and Maintenance Articles 0 12-25-2002 07:00 PM
Head Maintenance Blues Tom Wood Her Sailnet Articles 0 11-21-1999 07:00 PM
