08-06-2010
Crealock 37
The heat exchanger tank was pretty crappy looking, got a new one and used my old core. I bought a new cylinder head assembly, studs, bolts, gaskets, o-rings, injectors, high pressure injector lines, etc.....about $3500 worth of stuff .
The head, header tank, injectors and fuel lines are back on the engine. Tomorrow I'll get the water pump, CSW pump, alternator and all the hoses back on and see if I can get her running. I've been wanting to find out how to bleed fuel lines, I'll be able to check that off soon.
If it wasn't for the fact I'm missing a lot of sailing, this has been enjoyable....other than writing the check that is.
Thanks for the input.
Dale
S/V Elnora
Pacific Seacraft "Crealock" 37 #312
