06-27-2010
What sealant did they use. Ports need to be bedded with the right sealant. It sounds more like they failed to properly clean and prep the acrylic or used the wrong sealant than anything else.
Acrylic glazing on boats should generally be bedded with Dow Corning 795 or Sikaflex 295 with the 209 primer. I generally recommend the DC 795, which is a structural silicone adhesive specifically designed for bedding glazing.
DO NOT USE ANYTHING ELSE... it will fail.
