06-27-2010
Originally Posted by Estragon
I just replaced an old Hood line drive furler with a Profurl, and it was pretty straightforward to install. I chose the Profurl over a Harken, because IIRC the Harken installation required the headstay to be cut, whereas the Profurl fit over the existing.
Can you approximate headstay length by measuring the sail? You'll need the exact length to install (one extrusion piece is cut to fit), but an approximate size may work for pricing and ordering.
I just did the exact same thing. I had my heart set on a Harken MKIV but after talking to several riggers, felt I needed the Unit 2 for my boat and that made the Harken a good deal more expensive than a Profurl unit. I am pretty happy with the Profurl except line that came with it seems undersized to me. Today bought a size larger line which I hope will fit my hand better. I just couldn't get a decent grip on the 5/16" stuff and found winching was too slow for my preferences. Hopefully, this will allow me a good enough grip to pull the sail in by hand.
Anyway, unless the rigging has recently been replaced on your 1981 boat, I'd say it would be foolish to install a new furler over the existing headstay. Might as well use the opportunity to get a new stay while you are at it.
FWIW, I got quotes up and down the bay and the Profurl units were the brand most often quoted. I often had to ask to get a quote for the Harken. The MKIV Unit 1, was about the same price as the Profurl, but my boat (36+') was right on the breakpoint between units and every rigger I spoke to suggested I'd be happier with the Unit 2, as did the person I spoke to at the Harken booth at the Annapolis boat show. The Profurl unit was sized for a boat up to 39' but lacks some of the features of the Harken.
PalmettoSailor (formerly midlifesailor)
s/v Palmetto Moon
1991 Catalina 36
