06-27-2010
This is a really stupid way to do it... it makes it very likely that someone will step on the cables while working at the mast... A single standpipe type through-deck connection would have made more sense and provided protection for the cabling from the genoa.
Also, I don't see a protective rubber grommet over the aluminum mast edges in any of the holes. That alone is a good sign of a bad installation—especially around the two black wires exiting on the port side upper hole.
There should have at least been a stainless steel guard over the area to prevent the genoa or feet from damaging the wiring. Something like what you'd find over a properly installed dorade cowl vent.
