06-28-2010
It would help if you said what make and model depthsounder you had, since this could be a known issue with it. Also, have you tried using a different display of the same make and model, since the displays are usually far more likely to go bad than the transducers, and doing that might tell you which component is bad. If a known good display works on the transducer, then your display is shot... if it doesn't then the transducer is shot and the display is an unknown.
Of course, if you test your display on the boat you got the working display off of and it works, then the display is fine...but you won't be able to tell that without testing it with a good known transducer.
