06-28-2010
I understand you're at wit's end and, from your post it's clear you're not familiar with boat electric stuff. That's the bad news.
The good news is that as you have a smallish boat it can't be all that complicated, even if the PO has done a job on things :-)
Here's what you can do:
1. Be absolutely sure before you touch anything that there's no shorepower or inverter power (115VAC) on the panels. How to do that? Unplug the shorepower cord. If you have an inverter aboard, be sure it's turned OFF.
2. Plan to spend several hours with a flat-blade and a Phillips head screwdriver, some light sandpaper or emory paper, and a clean rag. You need to undo, clean, and reconnect ALL wiring connections. Start at the battery with the negative cable. Clean the battery lugs and the connector. Be sure all connections are clean and TIGHT. Work your way to the fuse/breaker, then to the panel. Undo every connection at every switch or breaker. Clean with light sanding and reconnect.
When you do the checks, be absolutely sure the connectors are intact. If any are suspicious, replace them
3. With the battery cables disconnected, undo the connections to the starter motor, and clean them/replace them as neccesary. Be very careful not to turn the threaded stud on the solenoid when you're backing off the nut. Use two wrenches.
4. Reconnect the battery cable(s).
Now, see what you've got. If you still have problems, it could be a bad switch or two. Could also be corrosion on the fuses, if any. Clean them and try again.
Try to avoid a newbie mistake: finding ONE problem (like a loose connection) and, because that fixes the immediate problem, believing you're good to go. Most often, there are more things wrong as well. It really pays to be thorough.
Take your time, have a beer, and count it as a learning experience with your new boat. If you do a good job, when you're finished you'll KNOW what isn't wrong, and where not to look :-)
Bill
