Pulsing kerosene stove - Page 2 - SailNet Community
post #11 of 21 Old 10-13-2010
Originally Posted by niebur View Post
A GRAVITY FED kerosene stove??? Never heard of such a beast. All kero stoves I know are pressurized.
And yes, the tank is close to the burner. In a well-designed stove the tank gets warmed up by the burners so usually you don't have to pump it up again during use. If there is a need for manual pumping, I take it as a sign that I have to refill the tank.
Just curious why you say this, when the OP clearly said:
It's a 3 burner hillerange
it seems to pulse more with a full tank
and the tank isn't close to the stove.
sailingdog is offline
post #12 of 21 Old 10-14-2010
I am not familiar with that particular model. My point was, since you expressed doubt in a previous posting that the tank could be close to the stove, I wanted to explain that this is by no means an unusual feature, and that there is actually a reason for it. Quite possible that there are stoves, like the OP's apparently, that are different and that would require therefore additional pumping during operation.
But my main point was that I cannot imagine a gravity fed kerosene stove, or one that has a ventilation hole that could become plugged
niebur is offline
post #13 of 21 Old 10-14-2010
A lot of diesel stoves are gravity fed, so there's really no reason a kerosene stove could not be.
post #14 of 21 Old 10-14-2010
Completely different beasts. Diesel "stove" is pretty much a misnomer. They are really heaters, with some of them having the opportunity to put a kettle on top. They are designed to burn for hours (or days) on end and take correspondingly long to get started. You would not want to cook on a diesel stove except if you are in a cold climate and it is on anyways. Kerosene stoves are just that, cook stoves that are usually on for the time it takes to cook dinner and are ready for that in a minute or two (pre-heating).
OK, admittedly, the situation is slightly more complicated. Force-10 used to make a heater that uses pressurized (vaporizing) kerosene. Unfortunately, now you can only buy it with propane burners.
--Ernst
niebur is offline
post #15 of 21 Old 10-14-2010
Ernst—
Growing up, I used a gravity-fed kerosene stove at a cabin in NH quite a bit. Don't see much issue with fitting one aboard a boat. You'd need to gimbal it, but that's pretty much the case with all stoves—especially on a monohull.
--Ernst
post #16 of 21 Old 10-14-2010
Ernst—
Was that a cooking stove or a heater (like a Diesel stove on a boat)? I can much more easily envision the latter than the former.
Somehow I doubt that a gravity-fed gimballed kerosene stove (with the tank necessarily gimballed well above the burners) will be a huge success for cooking...
niebur is offline
post #17 of 21 Old 10-14-2010
It was a stove. As for the tank, why would you need to gimbal the tank if it was independent of the stove???
post #18 of 21 Old 10-14-2010
Right.
Having the tank separately (and clearly above) the stove, the former connected to the latter by a flexible (oil and of course heat-resistant) hose that will not interfere with the gimbal.
And, of course, in addition the hose must not fail from the constant movement and transform the stove into an instant flamethrower right there in the galley.
Why in the world has nobody before had THAT idea?
niebur is offline
post #19 of 21 Old 10-14-2010
Niebur—
I don't see why you think the tank has to be mounted anywhere near the stove. It just needs to be higher than the stove, but does not need to be located anywhere that would lead to a leak pouring kerosene over the stove.
Attaching a fuel line to a gimbaled stove has been done on a lot of boats... and isn't rocket science to anyone but you...
post #20 of 21 Old 10-14-2010
Niebur—
You know, the whole point of the exercise is that the hose contraption does NOT become a contribution to rocket science
niebur is offline
Big Stove vs. Camp Stove tjgault Provisioning 14 02-06-2013 03:52 AM
Kerosene cooking stove questions junaido Gear & Maintenance 2 06-12-2010 03:10 AM
replacing the stove: alcohol converted to kerosene? deckhanddave Gear & Maintenance 13 12-14-2006 05:03 PM
yellow flame kerosene stove karlwestman Gear & Maintenance 0 09-08-2006 05:03 PM
Taylor kerosene stove adieu Gear & Maintenance 1 10-10-2002 03:45 PM
