Old 07-02-2010
telekitr's Avatar
telekitr is on a distinguished road
Tank cleanout
Hello everyone...we are currently in the process of rebuilding our Passport 40 and are at the point of wanting to do a complete cleanout and scrubbing of both our SS water tanks and our Diesel fuel tanks. As these tanks are quite long, and with limited access ports, this poses quite a challenge.
Does anyone out there have any insight into how this is done, equipment used, techniques??? Any information would be greatly appreciated...
Thanks in advance....
Ernie
S/V Iemanja on Lake Champlain (for now..)
Burlington Vermont
Old 07-02-2010
If you have limited access ports then you probably won't be able to clean the tanks very effectively. Most larger tanks are baffled internally, and the baffles will prevent any real attempt at cleaning them. One thing that may work is high pressure steam cleaning of the tanks... but again, it would be limited by your access to the tank interior.
Adding additional access ports would facilitate cleaning the tanks and also help with inspecting them in the future.
Old 07-02-2010
RichH's Avatar
RichH will become famous soon enough
I have a 'Perryboat'.
Access ports can easily 'sistered' over cutouts on the OEM tank, easy to apply 'studs' for the new access plates by simply drilling and tapping through the OEM tank from the inside.
BTW .... I have a black iron fuel tank that I 'rebuilt' (in place), simply 'lined' the internals with FRG and epoxy (built a new tank INSIDE the OEM tank).
For potable water tanks, same process but use a NSF/FDA 'rated for potable water service' - a low amine epoxy. do websearch "NSP-120". Lining epoxies are simply 'rolled on', like a barrier coat. Used in a lot in commercial applications.
Old 07-02-2010
One epoxy that would be suitable for potable water tanks is CeRAM-Kote 54, which is specifically designed for lining potable water tanks.
Product Reviews Cruisingdad Gear & Maintenance 104 02-28-2012 04:57 PM
11 Year Test Report - Star Tron / Sol Tron Maine Sail Gear & Maintenance 14 03-26-2010 07:42 PM
diesel tank cleanout j34035 Gear & Maintenance 30 02-15-2010 03:07 PM
Flexible holding tank installation sarafinadh Gear & Maintenance 29 10-17-2009 07:46 PM
Building a head tank Irwin32 Gear & Maintenance 6 11-05-2006 12:24 AM
