07-04-2010
Maine Member
Wow! You need to install a new check valve at the top of that loop - ASAP! If there isn't one there now (hard to tell), there should be! The loop is a vacuum breaker, and should not allow liquid to flow back to the bilge! Also, those hoses all look pretty nasty (old and cracked!) - I'd do myself a favor and change them all with approved "exhaust" grade marine hose before you find your boat on the bottom! Happy plumbing!
