Temperature Flucuation - Help - SailNet Community
post #1 of 2 Old 03-31-2003 Thread Starter
I went on my first sail of the season this weekend (before the snow hit) on the C. Bay. When I was coming in I noticed my engine temp was flucuating between 150-170 degrees. The temp would hold steady at around 150 then start to climb, then it would come back to the normal (for this boat) temp of around 150. I have never encountered this before. Any ideas? I have run the engine at the dock a couple of times prior with no noticeable change. Any input is appreciated. Is this a problem?
Rookie
rookie00 is offline
post #2 of 2 Old 03-31-2003
A couple of things come to mind. A sticking thermostat in the radiator? Or, how about the impellor in the raw water pump?
clayton is offline
Topside temperature vs. color jb2of3 Gear & Maintenance 15 10-25-2003 08:33 AM
