Old 07-06-2010
QuickMick's Avatar
QuickMick is on a distinguished road
winch trouble
I tried to tighten the jib halyard and the winch had a failure. the handle goes in fine, then all that happens is the faceplate spins... no winching action. it spins in both directions. its a barlow. anyone experience this? seems like it may have slipped a gear? any tips on how to fix it?
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
Old 07-06-2010
svHyLyte's Avatar
Old as Dirt!
svHyLyte is on a distinguished road
Broken or weak paw spring(s) coupled (I'll wager) with old thick, stiff grease. Easy fix with kerosene, 3-in-1 Oil and a little winch grease for the shaft coupled with a replacement spring or two. It'll take 30 minutes max.
FWIW...
Old 07-06-2010
ASA and PSIA Instructor
Most likely the pawls are not operating. The springs may have broken, or accumulated grime may be causing them to stick.
Winches should be inspected annually. serviced as needed (annually is good). Take them apart and clean. If the springs are broken you need to find a source, search for other threads.
Old 07-06-2010
svHyLyte's Avatar
Old as Dirt!
If the winch is old and you cannot find replacment springs you can make do by finding little tiny brass safety pins at a milinary or sewing shop and triming the pointed end off one leg and the safety cover off the other. With squeeze and a little 3-1 oil, it works every time.
FWIW...
Old 07-06-2010
Remember, DO NOT GREASE THE PAWLS. The bearings should be greased, but the pawls (little metal comma shaped pieces) should only be oiled lightly. If you grease them, they will gum up and stick...if this happens at the wrong time, you could get hurt very badly.
It's Winch Servicing Time Tom Wood Gear and Maintenance Articles 0 10-17-2002 08:00 PM
It's Winch Servicing Time Tom Wood Her Sailnet Articles 0 10-17-2002 08:00 PM
Using Winches Safely Sue & Larry Gear and Maintenance Articles 0 08-18-2002 08:00 PM
Titan’s Viper Series Winch Handle Dan Dickison Gear and Maintenance Articles 0 10-05-2000 08:00 PM
Titan’s Viper Series Winch Handle Dan Dickison Racing Articles 0 10-05-2000 08:00 PM
