Old 07-07-2010
cruisingmom is on a distinguished road
groco pressure tank installation
Hello All
I just purchased a Groco 1 gallon pressure tank on E-bay which came with no instructions. My guess is I just install in with a t fitting into my existing water system after the par pump and that's all that is required. However I am looking for advice as to whether I need to do anything else - could it really be that simple? Thanks for the reality check
Andy
Old 07-07-2010
Are you talking about an accumulator tank?? Yes, it is that simple.
Old 07-07-2010
groco accumulator tank PST-1
Yes - this is an accumulator tank - 1 gallon capacity. I was trying to relate this to the accumulator tank on my well. But the well tank has the pressure gauge and the electronic pump switch. I was thinking that if I hook up the Groco after my par water pump it is just an in-line connection without any additional gauges or hardware - just an in-line accumulator. Do I have this correct?
Thanks
Andy
Old 07-07-2010
Yes, all the Groco tank does is sit in line with the pressure pump and IIRC has a membrane in it to help stabilize the pressure in the water system and reduce the pump cycling.
Old 07-07-2010
gershel is on a distinguished road
My boat had one in it when I bought it 13 years ago. My water system worked OK, so I never messed with it. A few weeks ago I was having a problem, so I checked the tank. Turns out it has a air valve on top that looks like a tire valve. I went on Grocos' site, and they said to check the pressure regularly with a tire pressure guage for 28-30 lbs. Mine was 8-10, so I pumped it up with a bicycle pump.
I don't know why they don't include this in their instructions, but its on their website.
Marc
Pressure testing a fuel tank / system Gladrags1 Diesel Engine Forum 16 11-06-2009 01:23 PM
Flexible holding tank installation sarafinadh Gear & Maintenance 29 10-17-2009 07:46 PM
Fuel Tank Installation ISLANDAH Gear & Maintenance 8 10-06-2006 08:40 AM
Breadmaker aboard CHRISTINE-R Provisioning 21 08-14-2006 11:43 PM
Flexible Water Tank Installation Michael(zuzu) Gear & Maintenance 4 08-15-2005 02:15 PM
