Old 07-07-2010
lapworth is on a distinguished road
Smoking fiberglass
Last night was a little warm but I need to do some fiberglass work. Well I mixed a small batch and used most of but the stuff I left in the pot started to smoke while working. Could I have used the smoking glass ?
Old 07-07-2010
Sea Slacker
brak is on a distinguished road
just to be a stickler, you probably mean epoxy. epoxy cures with production of heat and, especially if it is hot outside, it may begin giving off smoke or even catch fire (happened to me once). generally, once it starts getting overheated, that means it is being cooked and the resulting material will be theoretically more brittle and less strong than properly cured.
you could have quickly cooled it (dispersing it in a thin layer over a large surface like a single-use tray may help), also using slower hardener will increase its pot life in hotter temperatures.
Old 07-07-2010
Actually, all of the reactions for curing resin—epoxy, Polyester and Vinylester—are exothermic and can generate significant heat. Any of the commonly used resins would smoke, especially in hotter temperatures and if they are in a tall narrow container, rather than a wide-flat container.
No, using it would have been a mistake.
Things you can do to help the resin take longer to cure:
1) refrigerate or cool the components prior to using them... the components will have to heat back up to become really active.
2) use a wide flat container so that the heat from curing is readily dispersed
3) use less catalyst for polyester/vinylester resins and a slow hardener for epoxy resins.
Old 07-07-2010
Thanks for the advise guys but my wife already hates when I work with this stuff so the hole frig idea would be a Big No!
Old 07-07-2010
paulk's Avatar
paulk is on a distinguished road
Instead of the fridge, you can also put the bottles in an ice bath- like a wine cooler bucket.
Old 07-07-2010
tommays's Avatar
I had the same thing last night BUT new it was going to happen so i spread it out over the core really FAST to avoide the heat issue
If you are going to keep working in the current heat i would go with a slow hardner as my brand comes in 3 speeds for weather changes
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 07-07-2010
You can also put the container you're mixing the epoxy in into a water bath or ice bath.
Old 07-07-2010
mitiempo's Avatar
Years ago I switched to using only slow hardener unless working in cold conditions (I use West) and it gives you the extra working time you often would like. Still cures in a reasonable time for sanding, etc. I use the West pumps so mixing is fast and easy. I mix in smaller amounts and if I need more it only takes a few minutes to mix another small batch as there is no measuring.
Brian
Old 07-07-2010
QuickMick's Avatar
QuickMick is on a distinguished road
I use the 'small batch' approach too, it also helps insure you get to use all your material before it starts to set
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Yacht Broker
The legacy of Philip Rhodes GoodOldBoat Buying a Boat Articles 24 03-09-2012 04:06 PM
High Tech vs traditional-Comments? Pangaea General Discussion (sailing related) 38 08-07-2007 01:07 AM
Cleaning Fiberglass Hulls and Decks Sue & Larry Her Sailnet Articles 0 03-07-2002 07:00 PM
First Fiberglass Repair SailNet Gear and Maintenance Articles 0 09-01-2001 08:00 PM
