07-08-2010
Pearson 303
Before you buy a new switch, try and turn just the outer cover with the key slot. It may have moved and is no longer aligned with the internal slot to the tumbler. By the way, these keys/tumblers are very simple. I forgot our key at home a few weeks ago and was able to easily turn the ignition by using a padlock key of roughly the same size and wiggling it around a bit in the slot. To shut it off I didn't even need to insert the key all the way.
