No shafts through the hull on a Gemini, so no need for a packing gland of any sort. They use a bridgedeck mounted westerbreke 27 diesel with a Sillette Sonic Sail Drive leg, that mounts to the aft end of the bridge deck and looks much like the lower end of an outboard engine.
Not to be too picky but actually it's a Westerbeke 30B
Gemini 105's are kind of unusual with a single diesel mounted center on the bridge deck (middle cockpit locker), the Drive leg (lifts via hydraulic pump) is fully articulated and turns with the rudders - providing for tight turns under power, but not as good as dual motors would provide.
My A/C raw water strainer cracked one winter (forgot to drain it). For four weeks I went crazy with a couple inches of water in the bilge on occasion. Found the crack one day just tearing everything apart. It only leaked when boat wake going by rocked the boat. That leak/strainer was in the aft cabin, the water was in the forward bilge.
After that I installed bilge pumps.
I'd be seriously surprised to find it was a cracked hull, that would take some doing. Just because the water is in the hull by the sink does NOT mean that is where it is coming from.
Gemini's are built on a platform from start to finish, then launched from that platform - there is nothing to drop it from or too.
After they are launched they sit in a slip for up to many weeks getting outfitted, rigged etc. If it was a factory originated crack it would have shown LONG before you took delivery.
Perhaps the reason PCI isn't returning your calls is
a) they know what I just wrote above and are expecting you to call your insurance company if it is in fact a cracked hull.
b) since you are a dealer for them, you should damn well know that yourself.
c) they are aware that you are bad mouthing them here (look up user WillH someday - He's moved on, but it goes to show they do read these forums you know.)
Anyway, Mr. dealer who doesn't know diddly about PCI and the yahoo group - welcome to Gemini ownership.
