07-08-2010
Most, if not all, of the powerboats I work on have sea chests. They do a good job of reducing the intake thru hulls. However there are concerns.
The sea chest and thru hull must be properly sized to exceed the demands on the system and that generally means worse case (i.e. everything running whether it does or not). That can mean a large thru hull, strainer, valving and chest.
Most effective sea chests have a clear top so that you can "see" the sea water flow or look for constrictions.
If the raw water strainer needs cleaning, you either have to shut down the entire system if you have one intake, or change valving if you're port and starboard.
Then there's the problem of running hoses containing sea water from the chest to the parts of the boat (head and sink for example). A leaking hose can do considerable damage to the vessel as well as put it in harms way.
Most of the power boats I'm familiar with have the sea chest in the engine room and since 99% of the raw water's used there, long runs and leaks are generally confined to that area. We have port and starboard as well as upper and lower intakes and valving. Since the boats use fresh water for toilets and don't have salt water available at the sinks, the needs are somewhat diminished.
I know of a few sailboats (mostly home made) that get by with port and starboard lower intakes, but they have dual filters and valving.
If you were to go with a single raw water thru hull, then you might save a couple thru hulls and shutoff valves. I don't know how that would affect the failure analysis numbers compared to adding salt water filled hoses to the head(s) and sink(s).
It might be worth considering a somewhat larger intake with, a "Y" connection. One part of the "Y" would go to the engine and the other maybe the sink as the galley tends to be close to the engine room. My only concern with that is if the engine draws a lot of water, you may find that the sink pump doesn't provide enough water or pull or worse, the sink takes too much water away from the engine.
Finally, the best designed sea chests have an access above the water line. This means we can keep the systems running, remove the top, and still get things done. That can be a tough problem on sailboats where space is a premium and heel considerably more than most powerboats.
Capt. Douglas Abbott
USCG/MCA IV/C.I./M.I. 500-ton Oceans
PADI MSDT
