halyard slap - Page 2 - SailNet Community
post #11 of 13 Old 07-08-2010
Halyards under tension don't seem to slap internally too badly - as a rule. I think a lot of the internal slap comes from unsecured wires - the VHF coax or aftermarket wind instruments' cable perhaps the most likely culprits.
Some have run pipe insulation foam over the wires, others have attached un-clipped zap straps (wire ties along the wire - the long ends hold the cable itself away from the mast walls. But both of these could interfere with the space needed for the internal halyard runs.... and both techniques would work best with the mast down - but then you could probably work out a more secure and permanent (and seamanlike) way to do it.
Faster is offline
post #12 of 13 Old 07-08-2010 Thread Starter
QuickMick's Avatar
i just didnt like the notion of putting oddball lateral strain on shroud and didnt like the notion of the bungee hooks chaffing line over time... thought about it and have done it in a pinch
How inappropriate to call this planet Earth when it is quite clearly Ocean ~ Arthur C. Clarke
Quinn McColly
Macgregor Venture
QuickMick is offline
post #13 of 13 Old 07-09-2010
I haven't had internal halyard slap after tensioning them against whatever is holding them externally, (jib halyard to bow pulpit, extra halyards around hooks on spredders)-could it be your internal wiring that's slapping?
donlofland is offline
jib furler/reefer and halyard MtHopeBay Gear & Maintenance 19 02-22-2012 12:31 PM
Tale of the stuck halyard wlcoxe O'Day 0 08-23-2006 04:45 PM
Another lost halyard... pluscard Gear & Maintenance 13 06-26-2006 05:40 PM
halyard working load Randolph Bertin Learning to Sail 1 10-27-2003 11:12 PM
Rereaving the Main Halyard Dan Dickison Racing Articles 0 02-11-2002 07:00 PM
