Old 07-08-2010
zmountainman is on a distinguished road
Alarm sound volume
I suspect that there are many others frustrated with my problem....that is that most of the alarms and other electronic noises from my yachts systems are of a frequency and volume that are not adequate for my significant hearing loss.
Is anyone aware of a way to adapt amplifiers or of actually adding a second apeaker that is loud enough for old ears.
Old 07-08-2010
Gene T's Avatar
Gene T is on a distinguished road
My hearing is pretty good and I can only hear some of these devices if I am real close.
There is no really "easy" way that I know of to make them more audible. There might be an output that could be run to an external device on some, but not all. Sensors could be added to the beeper to signal another device but that is a lot of work. Microphones on each to your stereo? Whatever you use it will take more power too. If you want to take them apart and start soldering on wires then you have lots of options.
Gene
Currently in Long Beach, CA
Old 07-08-2010
A better idea might be to add a flashing light. A visual signal is often used for deaf people and might make more sense for you as well. It would also be a bit easier on any crew or nearby boats in a quiet anchorage.
Old 07-08-2010
mitiempo's Avatar
One of these:
Brian
Old 07-08-2010
Mitiempo—
That might be a little overkill...
Old 07-09-2010
WanderingStar is on a distinguished road
My low oil alarm is a loud brass bell. It's old school, but you won't miss it.
Volume of a tank (alcohol) harbin2 Gear & Maintenance 6 06-20-2010 05:47 PM
Cruising Long Island Sound bbyrnes Cruising & Liveaboard Forum 14 08-20-2004 07:51 AM
Oil pressure alarm question i670684 Gear & Maintenance 1 12-18-2002 12:40 PM
Sailing in Fog Sue & Larry Cruising Articles 0 08-02-2001 08:00 PM
Landfall—Prince William Sound Liza Copeland Cruising Articles 0 07-15-2000 08:00 PM
