Old 07-10-2010
EpicAdventure's Avatar
EpicAdventure is on a distinguished road
Propane locker for CNG conversion
We are looking at buying a boat (we might be getting very close here... kind of exciting and scary!)
The subject boat has CNG and I'd like to convert it to LPG. Few questions:
1) I don't know the specific model of stove, but from what I've read, I think the jets have to be changed to run off of propane?
2) What size tanks do most folks use? I was thinking that two of the 10 lb composite would probably work pretty well?
3) I was surfing on propane lockers and came to this page. I'm surprised that then vent appears to be at the top of the locker. If I were to build my own locker, wouldn't it make more sense for the vent to be at the bottom? Maybe that is because the round tank almost seals in the locker?
4) If I have two tanks (only one in use at a time) should the "reserve" tank also be in a vented locker?
Old 07-11-2010
kd3pc's Avatar
kd3pc is on a distinguished road
Epic
Depending on the stove, you may need to change more than the jets, should install a sniffer in the galley with a cutoff solenoid, depending on the boat, this ranges from easy to a week long ($$$) project
MOst are using 10lb and larger, as anything smaller will have to be filled frequently if you actually use propane. Good news propane is more readily available than CNG
the locker you point to only uses 1 lb cannister, almost too small to be useful. For the money you would be better to hang a tank on the rail. And yes, the vent has to be at the lowest point in the locker. I think you are seeing the feed line.
tanks have to be stored with vents also...
other than availability, my cng is fine
Old 07-11-2010
paulk's Avatar
paulk is on a distinguished road
There's a very good diagram on propane tank installation on the WM website, in their catalogue. Two 10-lb tanks sounds like enough to heat with, but you're not likely to run out. We get through most summers with just a 5, but we don't have a grill or bake much bread on board.
Old 07-11-2010
chuck53 is on a distinguished road
I just bought a boat that has CNG. I was concerned as availability isn't great for CNG.
Now that we've had the boat for 6 weeks, we've decided we like the CNG and don't plan to change it as it would be a pain in the butt to do so.
THere is a safety factor that propane doesn't have. If there is a leak, the gas rises as opposed to settling in the bilge as propane will.
Previous owner said he only had to fill his tank once a year and I can deal with that easily.
Old 07-11-2010
mitiempo's Avatar
It would depend where the op is and where he is planning to cruise. If offshore cng will not work as it is not available in many countries. If he is staying local and it is available in his area that is a different story. Propane is the fuel of the world outside North America and is readily available everywhere, sometimes under different names.
Brian
Propane locker on a Tartan 30 owlmtn Gear & Maintenance 0 06-06-2006 06:22 AM
Propane locker problems Irwin32 General Discussion (sailing related) 12 04-29-2006 09:21 PM
Propane Locker windship Gear & Maintenance 5 04-13-2004 04:55 PM
Propane Locker windship Gear & Maintenance 0 04-09-2004 03:24 PM
Refilling Propane Tanks Doreen Gounard Gear and Maintenance Articles 0 09-01-2003 08:00 PM
