07-12-2010
Or by clicking the link in my post above...
Originally Posted by arf145
Sounds like bacteria. Peggy Hall's shock treatment for water systems is basically: fill the tank, then add 8 oz of bleach per 10 gallons of tank water, then run the solution through all taps (hot and cold) until you smell the bleach. Let sit for at least 8 hours but no more than 24 (solution can be corrosive over time). Then drain and run clean water through all taps until no bleach smell exists.
You can find Peggy's description of this by searching Shock Treatment.
Tom
