Old 04-02-2003
GeorgeTay is on a distinguished road
Bilge pump
My boat has a manual bilge pump permanently installed. I am planning to install an automatic electric pump in addition to the manual one. Can I tie into the drain hose of the manual pump without worrying about the water draining back into the bilge?
Old 04-02-2003
pirateofcapeann's Avatar
pirateofcapeann is on a distinguished road
Bilge pump
You shouldn’t get any water back through the manual pump but the manual will pump back through the automatic, if it''s a centrifugal type like a Rule. You could put in a check valve close to the automatic pump but for the sake of safety it really should have its own through hull fitting and be a completely separate entity from the manual.
Pi
Old 04-02-2003
kimberlite is on a distinguished road
Bilge pump
you shouldn''t put a check valve in the line of a bilge pump.
eric
Old 04-03-2003
hamiam is on a distinguished road
Bilge pump
Eric is correct; you shouldn''t put a check valve in the line for the bilge pump as it increases the resistance and diminishes the flow rate. That being said, in many applications, if you dont have a check valve the water will backflow into the bilge as soon as the pump shuts off resulting in a pump that cycles continuously.
Old 04-03-2003
Bilge pump
the reason you shouldn''t put a check valve in the line is that if the valve gets plugged your boat sinks. we have no check valves in any of the primary bilge pump lines. To eliminate the back flow i installes a small fully automatic rule pump (500 gph) with a check valve and its own through hull. this keeps the bilge dry.
eric
Bilge pumps oz_hole Gear & Maintenance 1 06-06-2003 01:36 AM
Oily Bilge dscottl Gear & Maintenance 3 06-11-2002 11:29 PM
bilge pump DQ halyardz Gear & Maintenance 3 06-04-2002 07:36 PM
Bilge pump dilemma zeilfanaat Gear & Maintenance 3 04-19-2002 05:22 AM
Bilge Question r3333 Gear & Maintenance 0 11-08-2001 08:11 PM
