sewage backs up into head when boat heeled - Page 2 - SailNet Community
post #11 of 23 Old 07-13-2010
Senior Mumble
jbondy's Avatar
Originally Posted by ajf10 View Post
I am also concerned ... since the toilet doesn't seem to pump water through very well as it is.
I hope you do have a vent for the tank itself and that it's not clogged, otherwise the tank will be pressurized by the act of flushing the toilet. This could cause all the symptoms you've cited, with the heeling being a red herring. But if the toilet isn't pumping properly and it's not caused by a vent issue, then a rebuild or replacment is called for.
jbondy is offline
post #12 of 23 Old 07-13-2010
Senior Slacker
SlowButSteady's Avatar
Is the only solution to install a vented loop between the holding tank and head? Or, is replacing the joker valve enough to prevent backflow?
Yes.
Nope, not the ONLY solution. It may be the easiest remedy in this case. However, IF the tank's inlet fitting is located properly (i.e., on or near the tank's centerline), the tank vent will break the siphon (unless the tank is almost full; low, flattish, waste tanks being more problematic in this case). Also, a simple loop in the toilet-to-tank hose, with its "apex" as high as possible above both the toilet and tank, will stop the siphon from developing in the first place as long as you pump the toilet empty (i.e., fill the hose with air; something you should do with or without a vented loop) after each use.
SlowButSteady is offline
post #13 of 23 Old 07-13-2010
Senior Slacker
Joel could be right (giving you the straight poop? sorry, couldn't help it). But, as I alluded to above, it could also be that you're leaving the toilet-to-tank line full after each use. A five-foot length of 1.5 inch hose holds about half a gallon. If you don't pump the hose full of air, the only thing keeping the contents of the hose out of the toilet bowl is the Joker Valve (an untrustworthy item, if ever there was one).
post #14 of 23 Old 07-13-2010
Maine Sail's Avatar
The tank vent will only help the siphoning event to flow better.
Sorry but pumping dry won't and rarely clears the entire line when using the "dry" mode. Been the recipient of the remaining fluid on numerous hose changes on all types of marine heads.
I have seen MANY instances where siphons overcame a simple high loop especially when heeling. Unless your head is located above the holding tank on all points of sail there really should be a siphon break in this line.
______
-Maine Sail / CS-36T
Maine Sail is offline
post #15 of 23 Old 07-13-2010
Senior Slacker
ONLY if the inlet fitting is submerged, which can ONLY happen if the fitting isn't on the centerline of the tank AND the tank is almost full.
True, but as I said, the remainder will potentially leak past a bad Joker Valve with or without a vented loop. If the tank's inlet is not submerged (which can only happen with a full tank that has the inlet fitting improperly positioned) a siphon cannot develop (unless you've invented a new Physics that you're keeping to yourself).
I will grant you that there are many head tanks with fittings improperly placed. But, that doesn't contradict what I said above.
post #16 of 23 Old 07-13-2010 Thread Starter
Thank you for the replies. I do have a rebuild kit for the toilet, I just have not gotten around to installing it, will do soon.
The holding tank is vented to the outside of the boat. The tank inlet is unfortunately located on the starboard side of the tank, this is how ronco plastics suggested it be fitted, so it is what it is. I will install a vented loop in the discharge line.
If the vented loop has a valve and does not connect to the outside of the boat, will the valve prevent the loop from discharging foul odors into the boat?
Soggy 1975 Catalina 27 #2056
ajf10 is offline
post #17 of 23 Old 07-13-2010
The valve is designed to normally stay closed until a vacuum is created inside the hose by liquids trying to siphon... then it opens and breaks the siphon effect....and closes again. So, if it is working properly, it will not vent odorous gases into the cabin.
óCpt. Mal Reynolds, Serenity (edited)
StillóDON'T READ THAT POST AGAIN.
sailingdog is offline
post #18 of 23 Old 07-16-2010
I'm currently having the same problem as the original poster. I have a Jabsco toilet. I called Jabsco and talked to their "expert". He said it was the Joker valve. Here is his advice:
The most common is mineral build affecting the gaskets. Both urine and salt water contain high concentrations of calcium. When you stop flushing or allow the lines to dry out, calcium can build up over time and cause the seals to no longer line up properly to stop the backflow. This issue can be rectified by purchasing a gallon of white vinegar from your local market, pouring the vinegar into the bowl and pumping it on the dry bowl setting. Allow the vinegar to sit for 24 hour and rinse clean with fresh water. The vinegar should dissolve any mineral buildup that may have occurred.
I plan to try this first, then clean the valve, then replace it. Until recently, I had no problem so I can't see installing a vent (although I realize that would also prevent the problem).
harbin2 is offline
post #19 of 23 Old 07-16-2010
When I saw the lead I guessed Catalina 27. I have had the same issue, replaced the "joker" valve and have not had an issue. Old valve simply did not seal any more, regardless of backflow pressure.
Mark1948 is offline
post #20 of 23 Old 07-17-2010
I'd point out that the Jabsco brand heads are generally poorly regarded and often considered disposable. If you have to re-build a Jabsco head, my recommendation would be to REPLACE IT with something like a Raritan PHII or PHC head. This can be done fairly economically by getting a Raritan PHII/PHC LBA kit and re-using the bowl from your existing head--and will result in you having a much more reliable and lower maintenance head.
Naming and Renaming Your Boat Sue & Larry Cruising Articles 0 12-15-2003 08:00 PM
Sailing Basics Steve Colgate Seamanship Articles 0 03-09-2003 08:00 PM
Sailing Basics Steve Colgate Her Sailnet Articles 0 03-09-2003 08:00 PM
buying first boat jerrycooper14 Boat Review and Purchase Forum 21 04-23-2002 03:15 PM
How to Choose the Right Boat Don Casey Cruising Articles 0 04-20-1999 09:00 PM
