Old 07-13-2010
jobi is on a distinguished road
propeller brake ?
my boat has no propeller brake, this means the propeller is constantly turning when the boat is in motion right?
if so then the bearings and bushings take a constant strain, what do you guys do about it?
Old 07-13-2010
deniseO30's Avatar
Lies about her age
Keep it in gear that simple
Old 07-13-2010
priscilla's Avatar
priscilla is on a distinguished road
What model transmission do you have? Usually if you put your gear shift lever in the opposite of your direction of travel the prop won"t spin. I shut my engine off with the gear in forward, then put it in neutral and it won't spin. I understand, except for the noise, the spinning prop won't do any harm anyway.
Priscilla
Old 07-13-2010
depends on the transmission. Some can clearly be damaged by the prop spinning, since they don't get the proper lubrication.
Old 07-13-2010
Gene T's Avatar
Gene T is on a distinguished road
Actually not a simple answer. Depends on the engine/transmission. Some Yanmar manuals state that you should let it spin and that you can damage the transmission by putting it in reverse. Some state the opposite. I sailed on one boat that used a vice grips to lock the shaft with the two bladed prop in line with the keel. There is also a fancy locking device you can buy. If you have a folding or feathering prop you can safely put the engine in reverse. Anything else and you need to see what is recommended by the manufacturer.
Gene
Currently in Long Beach, CA
Old 07-13-2010
il take the magnetic strap brack systhem from an old stationary bike.
should be an easy fix directly on the shaft from the inside.
Old 07-13-2010
jerryrlitton's Avatar
Oathkeepers member
jerryrlitton will become famous soon enough
Send a message via ICQ to jerryrlitton Send a message via MSN to jerryrlitton Send a message via Yahoo to jerryrlitton Send a message via Skype™ to jerryrlitton
Darn it, I know this has been talked about a lot, to ad nausium however I maintain there is more drag in a spinning prop, at least in the air. I do not mean feathering which is entirely different. I mean a fixed-pitch prop.
"People that values its privileges above its principles will soon lose both."
Benjamin Franklin
"Those who hammer their guns into plows will plow for those who do not."
Thomas Jefferson
"First they ignore you, then they ridicule you, then they fight you, then they agree with you."
Ghandi
Old 07-13-2010
Jerry—
Maine Sail did a test... and no, there isn't, at least for a fixed prop on a boat.
Old 07-13-2010
Oathkeepers member
Another drag test, here is a link that is pro your point.
http://www.catamaransite.com/propeller_drag_test.html
Benjamin Franklin
Thomas Jefferson
Ghandi
Old 07-13-2010
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Originally Posted by jerryrlitton View Post
... I maintain there is more drag in a spinning prop, at least in the air. I do not mean feathering which is entirely different. I mean a fixed-pitch prop.
It depends on the precise shape and pitch of the prop. It does work for helicopters with their rotors correctly pitched (and gyrocopters, and maple seeds, etc.). However, a boat prop would only create more drag when spinning IF there a concomitant increase in "lift" along the aft surface.
Propeller choice for Helms 30 ACWbuff Helms 7 04-11-2011 11:15 AM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Choosing a Propeller Mark Matthews Gear and Maintenance Articles 0 07-24-2002 08:00 PM
Propeller Problems Mark Matthews Gear and Maintenance Articles 0 05-27-2002 08:00 PM
Check the Propeller Tom Wood Gear and Maintenance Articles 0 02-25-1999 07:00 PM
