-   -   Refrigeration conversion (http://www.sailnet.com/forums/gear-maintenance/66460-refrigeration-conversion.html)
j34035 07-14-2010 10:29 AM
I am investigating refrigeration conversion kits. The 2 systems I am looking at are the Waeco Cold Machine and also the Frigobar package systems. This goes into my J/34c which is a lake-bound weekender/vacation boat, not a liveaboard. The present icebox is ~6 cuft with 3" insulation all around. It is top loading. My questions are:
-How important is freezer capability (to you) rather than making it refrigeration only
-Anyone have experience with either system that they would share
-Any recommendations different than the systems I have listed.
Thanks for your help!!
DD
CaptainForce 07-14-2010 03:32 PM
If you're planning a 12VDC unit I think those with the "Danfloss" compressors and the heat exchange with the air flow over coils by a small fan are the most energy efficient. Of course, heat exchange with the water has a better coefficient, but too much energy is required to pump the water. Many of these units with a cold plate can be made with the cold plate in a freezer box and a vented flow to an adjacent refrigeator box. Nigel Caulder has a great book out on marine refrigeration that has good insulation advice. Good insulation is MOST important to your success. Take care and joy, Aythya crew
mitiempo 07-14-2010 05:13 PM
Frigoboat is a very efficient system with water cooling and no water pump. Very highly rated (#1 by Practical Sailor).
Welcome to Frigoboat.com
DwayneSpeer 07-14-2010 05:46 PM
Cold Machine
I have a cold machine in a box close to what you describe. It works very well and I've used it continuously for several months at a time over three past summers. I installed an extra cooling fan that the fridge controller turns on and off as needed. It cools the compartment the compressor sits in. Mine has a less than 50% use factor i.e. the compressor is on less than 50% of the time when the fridge is turned on.
When I bought my boat used twelve years ago in had the fridge installed. It worked well over two of the referenced summers but when I was planning my third summer out I replaced it with a new one. It was a simple installation and accomplished one afternoon.
I like to be able to make ice cubes for my evening cocktail so a freezer is important to me.
svHyLyte 07-14-2010 06:31 PM
Dwayne--
I would appreciate knowing how you wired the extra fan to your unit. I'm dealing with having to replace a compressor/condensor unit now and may need to add supplemental cooling capability as you did.
Thanks--
j34035 07-17-2010 10:20 PM
Thanks for the feedback. I am leaning toward the cold machine with a small freezer with the door. No one seems to know anything about the frigibar (not frigoboat) systems. They are advertised for less than $1k and you can get a lifetime exchange warrenty with them and they are using the Danfoss BD50 compressor, but still I cannot find anyone that has experience with them. Again, thanks to all!!
DD
jdair101 07-18-2010 08:27 PM
I installed a nova-kool LT201-RT4 system in my 5.5quft box. I went with the freezer compartment so I can keep meat on the boat instead of having to take it home during the week. Oh ya I need ice cubes for the wifes drink. It has the danfos 35 compressor and I also added a second fan with ducting to vent the compartment outside the boat. The second fan hooks up to the same connection as the fan for the condensor.
When running it draws 3amps and is running for a bit less than 50% time. It made ice cubes in less than 18 hours.
I did add extra insulation where I could but am unsure of how much there is in some places. I know where I drilled the hole for the lines it has 3.5".
Customer service is good as I had a few questions yesterday and sent them a e-mail and they got back to me today (Sunday).
http://www.novakool.com/products/doc...eet2008pdf.pdf
DwayneSpeer 07-18-2010 08:57 PM
Originally Posted by svHyLyte (Post 622644)
Dwayne--
Thanks--
The compressor control unit has a place to wire in the auxilliary fan already installed. It turns it on and off as it needs it.
Maine Sail 07-18-2010 09:01 PM
DD
You should also consider the new 12V Sea Frost system. Cleve has developed a very cool new 12V unit to augment his engine driven refrigeration line. The customer service with Sea Frost is second to none in the industry. I am a customer for life because they've treated me beyond even my wildest expectations. Small company EXCELLENT products, support and service..
Sea Frost
f182 07-18-2010 09:33 PM
HI on Gallivant we installed an Australian system Ozefridge this has be a great system. Easy to retro fit in a tight, small opening ice box. Its 12 volt system with water assissted cooling for the tropics
Welcome to Our Website worth a look
