07-15-2010
Use Garolite G10 fiberglass. You can buy this material in various thicknesses. I'd recommend using 3/8" thick garolite and back the bolts with fender washers. 3/8" garolite has a rating of 50,000 PSI IIRC. It is easier to work with than stainless steel, doesn't rot like wood, and doesn't present galvanic corrosion issues like aluminum. It isn't cheap.
