How to install hardware on cabin top when I can't access the underside? - SailNet Community
Blogs
Old 07-16-2010
alex909 is on a distinguished road
I have a Beneteau 343 and would like to install a cam cleat on a 1" riser on each side of the cabin top to run my traveler lines through (currently, they go through rope clutches).
I need to mount them in a place that has no access underneath for me to screw on the bolt or add a backing plate. Is there a way to do this securely so that it can handle the loads? Do I fill the space under the screws with epoxy or some other kind of filler and then screw them on without bolts or backing? There is an access plate under the winch and judging by that, there is probably a 1" gap between the cabin top and the liner beneath where I want to put my cleats.
Pardon the ignorance, I've never had to drill a hole on my boat and I want to make sure I get it right. Please let me know if I haven't been clear in explaining my question. I tried to upload some photos of the location but the uploads kept failing. I can send pics on request privately if it'll help.
Thanks for the help!
Alex
Old 07-16-2010
jbondy's Avatar
Senior Mumble
jbondy is on a distinguished road
I may be wrong, but I think you have to cut thru the headliner and do it right. If the area of the deck where you're going to do this is cored, you have to seal the core so water won't penetrate and cause rot. See this:
Sealing Deck Penetrations to Prevent Core Rot Photo Gallery by Compass Marine at pbase.com
http://www.sailnet.com/forums/gear-m...utyl-tape.html
Regarding the headliner, I did the same to my boat. From the top, I drilled down thru the deck and headliner. Then I drilled 1" holes thru the headliner from underneath with a hole saw so I could place large fender washers and nuts on the bolts hat will be placed from above. I believe the fender washers will be enough backing in thei application because the loads will be light and in shear.
I then plugged the holes in the headliner with 1" plugs I sourced from Grainger. Photos:
Old 07-16-2010
Maine Sail's Avatar
Ideally you'll need to cut the headliner and create your own access plate. Try to match the other access plates that are already in use and it won't look Mickey Mouse..
______
-Maine Sail / CS-36T
Old 07-16-2010
jbondy's Avatar
Senior Mumble
A little harsh, don't you think?
Old 07-16-2010
Jeff_H's Avatar
Super Moderator
I don't think that Maine Sail was referring secifically to the ear and nose arrangement of circles on your project, as much as the more generic reference to a less than finished job as being "Mickey Mouse".
For what it is worth, I have used your method when I am able to get a neat arrangement of holes and Main Sail's method when I needed access and there was no good way to get an orderly arrangement.
Curmudgeon at Large- sailing my Farr 11.6 on the Chesapeake Bay
Old 07-16-2010
GeorgeB is on a distinguished road
Mainesail, my C34 headliner is similar to the one you had in your 320. What is your recommendation for an access plate? As you know, Catalina taps the coach roof clutches into a glassed in bronze plate so I do not have any other access plates to match up.
Old 07-16-2010
DwayneSpeer's Avatar
Old Fart
DwayneSpeer is on a distinguished road
Drill and seal properly as noted elsewhere and use fender washers. Finish off the interior with a cap made of teak and it will look very nice. I have several such installations on my boat.
Hey, can one of you guys pass me a crab?
Old 07-16-2010
Maine Sail's Avatar
No, not referring to you installation at all but the many Mickey Mouse installations I have seen over the years where two, three or four + different types of mismatched cover plates were used in the same area of the cabin. Even seen duct tape holding tin foil in place...
______
Old 07-16-2010
Thanks for the suggestions. I'm going to go with the idea of drilling a 1" hole through the liner under the mounting points and then plugging it with a white or wood plug. I'll be sure to seal as appropriate.
Old 07-17-2010
Maine Sail--
But duct tape and tin foil is so stylish... :-)
Mounting solar panel on top of dodger hardware? SanDiegoChip Gear & Maintenance 14 03-05-2010 12:24 PM
Main traveler moved to cabin top GaryT Gear & Maintenance 2 01-08-2007 05:14 PM
blisters on top of cabin stevefle Boat Review and Purchase Forum 9 12-25-2004 03:21 PM
Cabin top winch mounting boards larsfis Gear & Maintenance 1 03-03-2003 06:10 PM
Mounting Deck Hardware Tom Wood Gear and Maintenance Articles 0 06-25-2002 09:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
