Old 07-16-2010
oomfh is on a distinguished road
sealing threads on fuel filter
Installing a new filter unit - what do you seal the threads with that is gasoline resistant? Yellow teflon tape?
Old 07-16-2010
mitiempo's Avatar
No teflon tape. Just smear the gasket with oil or vaseline.
Brian
Old 07-16-2010
No gasket on this application - just pipe thread into (and out of) a housing.
Old 07-16-2010
jfurlong is on a distinguished road
Thumbs up
Permatex Ultra Blue RTV Silicone Gasket Maker
Old 07-16-2010
tommays's Avatar
While tapes will seal they have and issue with bits of tape getting down stream were it should not be
There are a number of items made by Gasoila ,Permatex ,ect that will seal without the bits problem
Form-A-Gasket® No. 3 Sealant is for sealing hoses on gasoline tanks
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 07-16-2010
Gene T's Avatar
Gene T is on a distinguished road
This should not happen if the tape is applied properly. Whatever the use is the tape should never be wrapped over the first thread and no more than 3 wraps.
For my own use I use tape on fuel fittings if necessary. Teflont tape by the way is not a technically a sealant, it is a lubricant. Also there is no difference in the formulation of the tape due to it's color.
Gene
Currently in Long Beach, CA
Old 07-16-2010
mitiempo's Avatar
Sorry, I was thinking of the filter element itself.
I'd use this:
Brian
Old 07-16-2010
tommays's Avatar
Well
At least on land HERE there is yellow color tape gas service tape that is required to meet code if you chose to use tape
While i have no issue with teflon tape it is offen used wrong and ends up causing needle and seat problems on gas motors
Tommays
Northport NY
Westerbeke Oil Change bossk Diesel Engine Forum 18 01-20-2010 06:48 AM
Spin On Fuel Filter Adaptors Blowfish Gear & Maintenance 2 09-17-2009 10:46 AM
Diesel Fuel Essentials Tom Wood Gear and Maintenance Articles 0 03-22-2004 07:00 PM
Diesel Fuel Essentials Tom Wood Her Sailnet Articles 0 03-22-2004 07:00 PM
Diesel Fuel Concerns SailNet Gear and Maintenance Articles 0 07-08-2002 08:00 PM
