07-17-2010
Originally Posted by imagine2frolic
You need to learn to unscrew things without breaking them. Unless you do that you will be paying a minimum of $60. an hour for someelse to break things for you. Unbolt the track, and turn it over is probably your answer.......i2f
well, smarti-pants, do you have any good ideas on what I can use to loosen the bolt/screw? Assuming, of course, that I cant get the track to unbolt (since those are long frozen in place as well).
Seriously though, would WD40 work? An pencil torch or heat gun? Small axe? Any ideas are welcome.
FWIW: i do like the idea of pulling the end bit off....gonna have to look at that tomorrow after i am done re-fiberglassing the piss-poor factory glass job under the floors.
