07-20-2010
Originally Posted by bljones
DON'T USE PRESSBOARD!
Want a cheap mount for a small, light solar panel?
Use 1" ABS pipe and fittings, found in the plumbing section of your local big box store. Use four 90 degree fittings and four lengths of pipe to create a frame, use stainless screws to fasten the panel to the pipe frame, like you see here:
then use the necessary combination of rail hardware fittings or hose clamps and more ABS pipe to attach it all to your rail. If you want to get fancy, paint the ABS white.
That actuallly looked pretty nice. What exactly is ABS pipe and what is it made of? On another note, how many watt panels are those? How do you connect it to your vessel?
Dr. S.
"Eh Winds Up, Doc?"
Bristol 32
