Old 07-21-2010
jaschrumpf's Avatar
1975 Newport 28
jaschrumpf is on a distinguished road
Extra-thick cabin top?
I bought a couple of Harken standard cam cleats for use with my main and jib halyards, and picked up the top-mounted fairleads as well. The problem is that a 3" #10 stainless bolt won't reach through the fairlead, cleat and cabin top enough to bolt it on the other side. I've looked around quite a bit and it seems that 3" #10 bolts are the max length anyone makes standard. I've checked the Home Depot-type places, Ace Hardware, little ma&pa hardware stores and even West Marine -- 3" is it.
Am I using the wrong equipment for the purpose? Should I have gotten the base-mounted fairlead rather than the top-mounted ones? I never expected the cabin top to be so thick, or that #10 bolts would stop at 3" (even 3 1/4" would have worked).
I'm talking using this
with this
Suggestions?
S/V Free Spirit
Monrovia, MD
Old 07-21-2010
tommays's Avatar
Is the top or the headliner ?
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 07-21-2010
SlowButSteady's Avatar
Senior Slacker
SlowButSteady is on a distinguished road
Don't forget to also put some sort of backing plate/block on the inside.
Old 07-22-2010
jaschrumpf's Avatar
1975 Newport 28
It's the top -- it just misses the headliner, so I don't have any issues there.
Is there a chain hardware store that carries that bolt, or do I have to order it from the website?
Thanks!
(I didn't forget the backing plate)
S/V Free Spirit
Monrovia, MD
Old 07-22-2010
Irrationally Exuberant
arf145 is on a distinguished road
Not quite as convenient as getting locally, but I've found that McMaster-Carr fulfills orders very quickly!
arf145
1987 Pearson 28-2
Chesapeake Bay
How to install hardware on cabin top when I can't access the underside? alex909 Gear & Maintenance 10 07-17-2010 06:28 AM
Cabin top mainsheets chas5131 General Discussion (sailing related) 17 11-25-2009 03:06 PM
Main traveler moved to cabin top GaryT Gear & Maintenance 2 01-08-2007 04:14 PM
blisters on top of cabin stevefle Boat Review and Purchase Forum 9 12-25-2004 02:21 PM
Cabin top winch mounting boards larsfis Gear & Maintenance 1 03-03-2003 05:10 PM
