Old 07-21-2010
lizardheadone is on a distinguished road
Topside paint coming off in sheets
I WAS getting ready to clean, sand, and paint topsides but while I was scraping off some caulk, a large sheet of paint came off instead. I investigated and it looks like I have 6 coatings on the topside. The weak bond is between the 3rd and 4th coat. I know the problem more than likely lies within two categories: bad prep job and/or incompatible coatings. The 3rd coating does seem to be soft in some areas and hard in others, so I was thinking it was a 2 part epoxy primer are something similar because of the variability in hardness (bad mix) and it looks like it was rolled on and had a high build. Looks almost like latex paint in its thick texture. I was thinking to be absolutely sure of a solid paint system, I will have to scrape the paint down to the weak bond, clean very well, then sand down to gel coat, clean, coat with interlux Primekote and paint with 2 part paint. My question: Does this seem reasonable or do you know of better/easier method to solve this problem? Thanks. Pat
Old 07-22-2010
tommays's Avatar
Its a bit of work to find a clean surface but the only way to ensure a good job
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 07-28-2010
oomfh is on a distinguished road
I have always felt that once paint is applied over gel coat - you'll be chasing scratches for the rest of the time you own the boat. Painting over the gel coat was an easy and quick solution - until now. If it were me, I'd take it back down to the gel coat and either revive it or apply another layer of gel coat. If this is a DIY project, you might consider talking with the helpful people at Mini-Craft of Florida.
Short term pain, long term gain, yachti, yachti, yachti . . .
Topside paint for wood strip planked? Frozensurfer Gear & Maintenance 3 05-31-2010 03:19 AM
Topside paint /refinishing/Coating charliea Gear & Maintenance 6 12-24-2009 04:46 PM
topside paint stevenm Boat Review and Purchase Forum 1 09-23-2002 10:00 AM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
